Having issues figuring out why my fuel pump wont stop running. (Just replaced). I suspected the relay got a new one still going. Ecm fuse is good. There is a BRAIDED GROUND STRAP near the fuel tank that broke and I cant find where is supposed to connect at. Any help or suggestions that dont circle back to what I've already done. Many thanks
94 4x4,01 Blazer
2001 Blazer 4dr 4wd LT
that ground strap goes to the frame near the tank.
Ok thanks I see it now. But I cant get in there to pop out that nut/stud. Is there somewhere I can re route that ground to. I got a 15 inch braided ground strap just dont know if it has to be on the fuel filler neck in between those hoses
I've also tried having a buddy hold it there to see if the relay will kick off like its supposed too but still runs even when key is out and relay is in
New fuel pump new relays what else new do I need to get haha
