Discussion Starter #1 (Edited by Moderator)
These are the springs that are currently on my 98 Step-side, they appear to be after market springs.They have different pad and end bushings etc. than any of my stock springs and have three leafs total.
Quick google says...
I'd say you have Z83 leaves from the description I gave 5 years ago :LOL:
You could be right but they look like aftermarket springs to me, I haven't seen the any stock GM leafs that build with same leaf shim or brackets. It had a Flaming River driveshaft and some new front end components.
can take some pics of the ZQ8 springs if you really need confirmation.
Its an 01 X cab.
also have a set of Blazer ZQ8s out if you need a pic of that too.
Its an 01 X cab.
If you could shoot me a close up of the down facing end of the helper spring I could compare it to mine. Harley, gave a good description of the three different leaf spring types. I can compare your pic to my springs and his description and see if it holds up...thanks.
