okay I was wanting to drop my ext. cab zq8. I'm wanting to go with spindles and blocks. My question is do i need to use shims and space the carrier bearing. Any info would be appreciated thanx.
Don
You need to use angled blocks, as far as the carrier bearing spacer, just depends on the truck, if you start having problems with it then you need it, i never used a spacer on my truck.
