1 - 20 of 28 Posts
i want to put a set of z06 wheels on my 01' X, but i'm yet to see a set of them on any s-series, anybody got a real pic? NOT A PHOTOSHOP EDITED IMAGE. i need a real pic of an s10 with a set of z06 wheels...i thinkit would look pretty nice but im not sure -=/
Deadbeat
http://www.sportmachines.com/history/twinsonoma.html
now that truck is a beast is all there is too it...it has z06 wheels but its been modified...ALOT..awd for crying out loud..i think z06's will only work on a 4x4, correct?....or you could use adaptors...
I rape little boys
yea i think you have to get som elike...2 1/2 inch adapter for them to fit...and that is like a $200-$250..and i donlt like riding with that much between the wheels..soo...but that truck is badass...lol...i want it...o.k time to go clean up..lol
Deadbeat
that things is almost a total sleeper....10.8 1/4 mile street legal?!?! i'd probably kill myself in that thing........
want my #... 911 beotch!!
nope, no go on true ZO6 rims on a 2wd, the spacer would be way too big and the wheels would rub all the time. hell, i think even the 4x4s would need a spacer. standard vette rims will fit cause they are narrower by like an inch or so. cause the ZO6 rims are like 18x9.5 up front i think. and the standards are like 17x8.5 or 18x8.5
oh and i would personally rip off my left testicle and present it to John Lingenfelter myself for that twin turbo 7.0 liter AWD sonoma
C5 wheels on a 2000 S10
So what would I need to put C5 wheels on my 2000 s10?? It's a 2wd V6. Thanks for your help.
:beer:
someone correct me if i am wrong but the 17x8.5s will filt the front with a 2.5 inch spacer. and the rear, i am not 100% but, 18x9.5s should fit with the same size spacer. im not too sure though. talk to 98ssonnos, he will know for sure.
heres what you need to do they fit with no problem
front is a 17x8.5 right so when you get the rims measure the bs on them. i think they are like 6.25 in front. on a s10 on a 17x8.5 you need a 4.75 bs to be ok wiht a 245 45 17 so the difference is 1.5 so you need a 1.5 spacer. just mesure the backspacing and then get back to me
rear they are slose to 7 inches and you need 5.5 bs so you need a 1.5 spacer also. just get the rims and get back to me ive done this before on a 94 s10 like 2 years ago when i still worked at the shop the spacers ran him i think close to 300
tony
hey im thinking of getting the 17 inch z06 rims for my 2001 jimmy 4x4 is it just me but wouldn't 9.5 inch wide wheels in the front rub another thing my truck is not lowered so what would be a good tire size to go with
up to sumthing
The ZO6 wheels are 17" X 9.5" in front and 18" X 10.5" back
Big Dick Daddy
i believe it is a 17x8.5 in the front, the tire is a 265 how are you going to fit a 265 on a 9.5 inch rim? oh and yes, i just looked at that truck and shot one. that is bad ass
98 SS ON NOS said:
THE 17X9 SS RIMS fit directly on the trucks you can go with the 17x11 in rear if you want
as for the vetts shoudl be bolt up also
11" in the rear? Will that fit without tubbing? I need to get a 10in wide rim in the rear, a 285 tire, 29 inches diameter...is this possible? I plan on having to cut out the fenderwells, but other than that, can it be done? Thanks.
If u look at the picture of the Front tire of the TT Sonoma it is 275 40 17 and that tire is for a 9.5" Rim.
You have to buy the aftermarket 9.5" z06's the 10.5 wont fit w/o sticking out or rubbing.
In the front 9.5 is pushing it. The tie rod end is the biggest obsticle.
local ass hole
ok heres the low down on the Zo6 wheel issue.... I have a set of Z06 wheels that will make it on my first gen, and heres how im doing it.... first of all the Z06 wheels have thge EXACT same offset as the C5 wheels like 614 streets has. second the backspacing on the vette wheels is 8 inches in the rear. they are 17x9.5 in front and 18x10.5 out back, the stock tire sizes are 265/40 or 45/17 in front and 295/35/18 in rear. in the rear of my truck I have exactly 6 1/2 inches from the drum to the first thing that the wheel can hit, do the math, that leaves exactly 1 1/2 inch that you HAVE to have to clear obsturctions but that would leave the wheel exactly touching somthing so you would go with a 1.75 inch spacer MINIMUM!!! that is what I am useing on the back of my truck and with a 305/45/18 it will not hang out any and will just sit flush with the fender, the front I will use the same size adapter but FULLY expect to rub somthing and will probly have to modify somthing. but that extra inch has to go somewhere and NOT outside the fenderwells.
1 - 20 of 28 Posts
