1 - 20 of 22 Posts
Member
what size would be good to run from the compressor to the tank?
would 3/8 be good enough, running thur a 3/8 in/out water filter?
is there any oil that gets into the airline, do you need an oil/water filter, or just one for water?
and how long does the hi temp line need to be comming off the compressor, and how how hi of a temp rated line do you need for that?
just need to get an idea of some of this stuff ill need to get, thanks
ALMOST DONE
i was told to use 1/2 line with a 3/8 ID...your gonna get oil through the line so ur gonna need a oil/water filter..just use a length of steel braided hose for the line all the way to the tank..talk to CAB on here..he helped me out with alot of questions i had
Member
cool, so 3/8 inside d would be the smallest i would want to use? how about the oil/water filter, would i have to get the larger size with the 1/2 pipe fittings? ( :( they are expensive)
what size line and what kind of filter come in the ready to go kits?
I <3 SPARKS
www.cp-performance.net (cp-performance on ebay) sells Parker steel braid line. Get the -6 size, as it's equivalant to 3/8" ID. The ends are swivel flared ends and you can find fittings for it at most local places, including the Parker store, which is where I recommend. I run a Campbell Hausfield (however you spell it) water seperator from Lowes and it works just fine. It's got 3/8 females on each side. I ran a 15 foot steel braid line from the compressor to my tank, and I've got a little slack. 15 ft should be just fine.
I <3 SPARKS
Primer, ya... I like to run steel braided line the whole way back... but you can run just like 3-4 feet of it, then use regular airline from there back... IMO, it's kinda tacky tho.
LayItLowS10, sweet.. yea. Braided is nice, looks killer too :D
Ol' Skool Member
Thanks cab.. While we are on the subject.. what do you all run for your intake system on your compressors? Just a little filter off the fitting? or what?
stainless braided what temp is to good for. im going to be fabricating an engine driven setup here in the future. one question i have is what type of fittings are on the head of the compressor. are there different styles and whats best
I <3 SPARKS
On mine, it has 3/4" NPT male ports.. I've got some 3/4" female elbows on top of it. York 210 or equivelant is nice... Autozone sells em as I've said in other posts for $85.99. Tell em it's for a 81 Ford F100.
As for the intake, I've got one of the little air filters. I got it from the ricer section at Autozone. It works good tho :D
former title junky mod
I have had my engine driven up and running for a year and a half now. I used regular air line for a while and never had a problem with it melting. I use hydraulic hose now, which in my opinion, is the best. The engine driven comp is obviously under the hood. I want my comp to look stock (when I do engine dress up I will do it to the comp to) for now. With black hydraulic hose it looks like a stock engine part. It is also cheaper then steel braided hose.
i was thinking hydraulic line whats it going for /ft?
if i go s/s braided the total line and fittings would be 100 bucks
what is the head of the compressor made of? aluminum?
damn im going with them 6n 15' for 55 bucks with fittings and crimped
1 - 20 of 22 Posts
