1 - 11 of 11 Posts
I don't plan to use A/C in my 2002 pickup build. (It's Colorado, we hardly sweat).
Anyway, the question: did any S-10 pickup NOT come with A/C?
I want the firewall-side heater box cover and they're just not to be found, at least by me.
They DO exist, right?
Thanks...
time to get cereal
I believe 2001 was the last year for non-AC trucks, but lucky for you a 2002 isn't any different.
The 4.3L uses an idler pulley in place of the compressor, the 2.2L just uses a shorter belt.
Controls:
Blower Box and Blower Motor (it's different too)
Recirculation door block-off
Can't you just leave the A/C controls on the dash. I did that on a 1st gen and everything worked fine. Of course when you set it to A/C nothing happened, but everything else functioned as normal.
On the 1st gen you gained 1 blower speed if you changed the resistor on the motor because non A/C only had lo, med, & hi.
You're right. Don't need the controls or the recirculation block off panel, but some people want it all, so I grab whatever is there to resell. Well I don't grab the motor or resistor because the yards charge close enough to new prices on those it isn't worth it.
At a minimum you need the firewall housing and blower motor. The resistor is the same for the 2nd gen between the AC and no AC.
That might be the case on the earlier 1st Gen, but the later interior style has the same number of fan speeds between the 2.
8/31/1897 - 4/29/2004
Controls:
Wow! I’ve never seen a second gen w/o AC
Yeah,I’ve only seen it on box bodies,..
Then again I live in the south. There’s not a big market out here for cars w/o air conditioning. My buddy had a Canadian model Tercel w/o AC,and literally couldn’t give it away,..we’ll,I finally bought it for a couple hundred bucks,and quickly resold it to another buddy once the tank was empty:haha:
1 - 11 of 11 Posts
