Hey guys are these any good
Specifications X124
Description 12"
Impedance 4 Ohm
Power Handling (RMS) 500 Watts
Frequency Response 27-150 Hz
Sensitivity 87.5dB
Magnet Weight 102 oz
Mounting depth 7"
Mounting diameter 11.0625"
Overall Diameter 14.75"
Diameter - Flat Side 12.875"
Voice Coil Diameter 2.5"
Xtant 12 the rms is 500 watts
Captain Obvious
I haven't heard them let alone seen an audio store around here that carries them, I hope they're worth the bucks they want for 'em!
xtant is some of the best quality subs and amps you can buy commercially for the money! their amps are by far better than their subs but the subs are still very good! the xtant 1001 mono amp i tested it and it is rated at a 1000 watts but it tested 1180 watts on 12.8 volts!!!!!!!! so if you had a higher output alt....wow! think of the power then!
