1 - 10 of 10 Posts
keep on keepin on...
I dropped my truck in Jan. and ever since I have a noise that I believe is coming from the driveshaft due to the pinion angle being off. well today I notched my frame and while I was there I decided to get some 2*angled blocks to fix the noise issue. well, it didn't change shit. now I am pissed. I am dropped 5 in. in the rear using belltech leafs and 2 in. blocks. wtf to do now? I am guessing I should go have the angle measured by a professional. any suggestions???
i saw what you did there!
driveshaft too long and binding up?
its quite possible.......
this is why i dont recommend messing with geomtry of drivelines by dropping vehicles like this
and never will try it.
just asking for issues and problems.
good luck hope you figure it out.....
Then how else do you drop it other tan a link setup?
x2 on higher degree shims and checking for drive shaft binding.
you can buy an angle finder for like 10 bucks FYI.
and everything is available to correct the geometry after altering the suspension of any vehicle, it's not rocket science.
Discussion Starter · #10 ·
remove mount to trans bolts
lift up on the trans and slide the spacer in
line up holes and reinstall bolts
torque to spec.
thx
1 - 10 of 10 Posts
