I have an 89 s-10 cameo 4.3 That will not idle down could use some suggestions. Thanks, Corey
S supersonicblue70 · Registered Joined Nov 25, 2003 · 4 Posts Discussion Starter • #1 • Dec 18, 2003 I have an 89 s-10 cameo 4.3 That will not idle down could use some suggestions. Thanks, Corey
R rodknock · Registered Joined Jun 22, 2003 · 1,039 Posts #2 • Dec 19, 2003 you mean high idle??? idle down huh not sure what you mean
B BlazerLT · Clean N' Dark Joined Sep 2, 2003 · 1,921 Posts #3 • Dec 19, 2003 IAC (Idle Air Control) sensor Remove and clean it and reinstall.
S supersonicblue70 · Registered Joined Nov 25, 2003 · 4 Posts Discussion Starter • #4 • Dec 19, 2003 Won't Idle down BlazerLT- Ok I will clean it out and see what happens Rodknock- I mean when I start the truck and let it run it should kick the Idle down on it's own but it wont. Thanks Corey TGIF-------------------------:drunk: :boobies:
