This might be out of the blue. But when wireing up your valves would u just wire them up to the back of the switches?
I don't have any problems on mine. The only place I have relays is for the compressors.luvinitlow said:i stongly reccomend using relays on each valve,that will insure that you have a good connection which means good voltage which means better response,especially at highr pressures...there is alot of voltage loss when you run the power feed thro the swicth box then directly to the valves...
jus my opinion...
