Depends on where you tuck it...keep it away from things that rotate, heat up, letting it flap in the wind.
2003 GMC Sonoma SLS extended cab 4.3L auto 4x4
And make sure to use sufficient hold down clips, clamps, zip ties, etc. to make sure the harness stays put and doesn't "wander" into any "danger zones", as previously described. Also, don't try it with the engine running! (Thank you Capt. Obvious!).
Zip ties to position...clamps to secure.
Discussion Starter · #9 ·
i need to find a way to get it away from the tire so i can relocate the clutch res
