Hey all. Trying to figure out what's wrong with my wiper on my driver side all the sudden that doesn't press hard enough to wipe the window with new blades. Does this mean that the arms bent too far the opposite direction usually?
Did the spring under the arm break or come off. If it still has spring tension it's possible you bent the arm while installing the blades if you really pushed outward on it. Compare the shape of the arm to the other side. Replacement arms are available for later years for around $25. There is a day or two old thread on changing them.
I can't tell they look the same, I swapped the side that wipes to the side that won't wipe and it still not pressing hard enough down to wipe for some reason the springs aren't broken
Just get a new arm. Junkyard or auto parts store.
Fixed. Simply bent the narrow ends to press more into the windshield. Wipes good now without buying!
