1 - 14 of 14 Posts
01 s10 4bd1t with a nv4500 & Toyota 1 ton dually
Had a 2.0 tdi in it first with a stage 3 tune with a 1756vk garrett turbo 235 hp 360lb but i wanted a mechanical diesel plus it took the teeth off a brand new timing belt so it bent the valve
But back to my original question will the moog 5664 fit or does anyone know of a heavier coil spring fit?
A 3.9L Isuzu Turbo Diesel.
Should be sweet with the turbo. I had an ‘82 Luv with the NA version. It was a slug but ran forever and got great fuel mileage.
The turbo on mine is garbage it max boost is 8lb the new turbo he221 will make it run🤯
You might call a spring shop with he particulars of what you want. They can probably spin up exactly what you need.
Discussion Starter · #11 ·
Nobody answered my question so I found out that my 2000 Chevy 3500 Coil springs work perfectly thanks anyway😔
1 - 14 of 14 Posts
