When I went to my truck this morning to drive to work, I smelled gas, checked the tank, and had to drive something else. I do have a spare tank from a 95 ext cab. Will it fit in my 93 ext cab?
I am sorry, I did mess up on the title, but I meant 93, not 94I don't see why it wouldn't. Sometimes have to get 94 s10 blazer parts for my 2nd gen 95 s10 blazer because what it shows for the 95 won't fit but the one for the 94 will. Just using this as an example.
Alright, that's what I planned on doing, I just wanted an actual answer before I got off of work. Thank youLook at each tank, see if they look similar, take mounting point measurements and if it's close use it, if not close enough just Fab up some brackets. It's pretty easy to do, doesn't take rocket science to fix.
How exactly do you want the title to read??Note: I found an error in the title. I meant to put a first gen 93, not second gen 94.
95 and 93How exactly do you want the title to read??
So you already changed it??95 and 93
YesSo you already changed it??
