1 - 12 of 12 Posts
NuLowz Customs
I have an s-10 and I currently have 245/50/zr16's on it... will I lay out without laying on the fender wells???
EX-Minitrucker
i'm running 225/50/16 and the truck sits on the fenders. so you won't be able to lay out with that tire size. I'm planning on upgrading to 225/45/16 which is the right tire size if you want to lay out IMO
Drop N Destroy
i have 245/45/17 and when i lay it down im on the fenderwells with my 2inch drop spindles on there 2
When people say they are on the A-arms does that mean you guys dont have drop spindles? Or do you guys have drop spindles and the arms are hitting the frame?
I have 215/45/17 24" tall and I am 2" form the ground but a 22" tall tire will lay with the stock fenders. that is on my 2000 I have 2" drop spindles and I am sitting on the A-arms/fender Real hard to tell what hits first
RUSTHOLYUM
Yes, when u hit lca's it means u either need tube's or u gotta notch frame or arm itself....also if u have a 2.2 97- and plan on layin 18 or larger..I found myself hitting my down pipe...just some fyi
Oh okay, So this problem is only for the 97-+ trucks? Seems like everywhere you look the 94-96s tend to have an advantage with lowering.
I also drag down pipe 2000 2.2
ok so on my 82 s10 i will need spidle and bagges for the front andnotch and bagges for rear Right? does anyone have spindle or bagges used for sale? iam on a tight buget
1 - 12 of 12 Posts
