1 - 2 of 2 Posts
Hi,
My tires are lookin pretty worn out. I see a lot of trucks driving around with there tires sticking out without haveing wide tires. I figured this is all done by the rims and backspacing right. Im also looking at lifting my blazer about 3 inches all the way around and it seems the Ill need a wider wheel base to stay on the ground. The reason I want the skinnier taller tires is so I can cut through the snow in the winter. Has anyone else did this, and what kind of rim size did you use?
T/A drivin foundin member
you can go 31x1050x15 on stock rims
1 - 2 of 2 Posts
