I finished my bodydrop, and plugged every harness back together, now i have vacuum issues. I have an 01s10 with the 2.2 and it only has vaccuum in like 3 places, they are hooked up, my truck starts for a second and dies. the fuel pump is on and i gave it gas and got it to start for 10 minutes, turned it off and it will not start again, my mechanic says its a vacuum issue and its either the canister on the fender, or the evaporater down by the passenger side frame horn, both have been moved and depending on their angle it will kickover or wont even turn on. has anyone had this problem? and if so what did you do to correct it? i need to drive my truck again!! thanks in advance guys...
