1 - 20 of 28 Posts
I just got done with my 3/4 drop, i used 3" coils in the front. I was just wondering why its a lot rougher going over pot holes than it was stock.. is this because im hitting my bump stops?, i cant tell. i cut about an inch off of them but thats not very much.
Sneaky White Person
Tundra
the springs are also probably a stiffer springs seeing as you have taken away 3 inches of it's travel. . .
Damn right I'm a maniac.
Sounds like you are hitting the bumpstops. Try cutting a little more off your bumpstops. And like everyone else said, avoid those potholes if you can. Your rims will thank you.
Discussion Starter · #16 ·
ok.... im just a little leery to cut too much off the bump stops, mainly because i dont want to cut them too far and end up hitting the frame, then i would have to notch that
murse
CustomS10 said:
:werd:
Pothole slalom is your new sport of choice
it should be olympic... i hate potholes too. just avoid them. and the stiifer the ride the better IMO.
www.putfile.com/sokr2004
just cut the whole bracket off...grind right on top of the welds, look in the how-to section, it tells you how to do it step-by-step with pics
1 - 20 of 28 Posts
