where should i put the presure switch?? on the tank and can i put the water trap on the bottom of the tank?? seems like a logical place to put it
the pressure switch should go on one of the ports on the tank that the compressor is connected to, the water trap can be put where ever u want, most people prefer to do it before the tank as it keeps the water out of the tank, which is the main reason for having the trap, and then they also put a drain valve on the bottom of the tank, so periodically they can drain any moisture out of the tank that mayhave gotten past the water trap.
