Here we go pawpaw
im just trying to come up with some ideas on where people mounted their water traps coming off an edc (98 4.3). i don't want it on the tank and i want it somewhere pretty easy to get to so i can drain it. im thinking of on the rad. support right where the battery was but was just looking for some other ideas. pics would be great
thanks
i mounted mine right behind the cab where the frame starts to bend up. You can not see it because the body hides it and it is so easy to drain with no mess on the truck.
lil' noma said:
I have it right before it hits the tank. It goes water trap-check valve-tank.
yeahh do what he said. i forgot about the check valve. the reason you wan tit far away, so teh hot comprssed air has a chance to cool down and create the moisture before it goes through the water trap so that it will catch it. if you put it on your compressor, the hot air will go through it and cool in your tank creating all the moisture.
