Ok, i got a 12 gallon 8 port tank, can i just mount the vlaves to the tank or should i mount them somewhere else??? and where would that somewhere else be???
thanks!!!!!!!!!!
want my #... 911 beotch!!
where ever you put them, make sure they are cway from water and moisuter.
Okay that makes sense so i should be ok mounting them right to the tank cause im putting the tank in the bed of my truck which is covered by a hard tonneau cover!!!
Fleetwood Truckers So. Cal.
The closer the valves are to the bag the quicker of a lift you will get. Try to mount them on the side of the frame near the front suspension. The back if you have a cut through of the bed mount the valves on the bags.
Which valves did you get, I'm guessing from AIM/Chassis tech because of the 8 port tank, but which ones did you end up getting?
Chad
my tank isnt from AIM (SHAIM) the tank has 4 ports runnin along the front ,1 on top, 1 on bottom and 1 on either side, i believe it is form airlift ,and the valves i got are 3/8" SMC's
Be careful with those SMC, make sure you do not put them in your engine compartment, the heat from the engine gets the valves way too hot. What I ended up doing is mounting them on the side of the frame and I had a cover made and bolted it on the frame to cover the valves.
