Discussion Starter · #1 · (Edited by Moderator)
this is the flange on the intermediate pipe that bolts to the catalytic converter on my 2000 s10 ext cab 4.3l vin w. i had to cut the bolt in half to get the intermediate pipe off cuz the nut was stripped and now i have to replace that press fit stud but can’t seem to find it anywhere online or autozone/oreilys, even tried a pick n pull and all the s10s i found have different 3 bolt flanges. can anyone tel me where i can get this stud? the size is m10-1.50 x 40mm
Looks to me to be GM part number: 15756879 (STUD,CTLTC CONV FLG(M10X1.5X40MM)(BUTTON HEAD).
Found it here:
Looks like you can get them from e-bay or Amazon. Seems to be about $8 on e-bay:
Hope that helps.
Found it here:
Hope that helps.
thank you so much bro! this has been a struggle for me for the last couple days! just ordered 2!
2003 S10 4.3 2WD
I just replace them with a bolt and nut from the hardware store it makes no difference in sealing/exhaust leaks.
Reactions: caveman110
And if it breaks when removing it a bolt is a lot easier to get out. More than likely it'll fall out. Also about $7 cheaper each. I usually have to heat those studs when they break and use an air chisel to drive them out even heated.
2003 S10 4.3 2WD
Yea, you should see what Toyota does with the o2 sensors you have to go back to studs. It's ridiculous honestly.
Chevy at least all of the ones I have owned are simple.
