1 - 16 of 16 Posts
Between the cavi 2.2 motor and the s10 2.2 motor besides the cavi was mounted sideways and wrong wheel drive?
94 s10 in progress
the exhaust manifold is different (thats why outs say TRUCK on them), i imagine the intake manifold is different too for clearance, otherwise year for year i would think it is the same motor
i can always swap intake manifolds and add on the turbo manifold... i just need to know if besides these two things that if its the same
BUMP... can we get a definite answer so i can buy this motor
motor is the same. nothing is different other than the intake and exhaust manifold. and no you can't bolt up the turbo manifold/header from a cavalier, the turbo will hit the brake booster.
ima make a custom turbo header so we got that outta the way...
just need an intake manifold and stock exhaust manifold... ill see what i got at work today
94 s10 in progress
naw all pre 98 heads are the same, same with 98+ (except flex possibly)
also you will need to bore some holes as all motor mount holes were not factory tapped and differ from the car and truck
7 P.S.I. is not enough
Hey Stivky aint the cavis over head cams and the s10 are over head valves am i right or am i wrong i though cavis were ohc
Sticky not Stivky
Discussion Starter #11
they both look the same... its just so hard finding a 2.2 truck motor
CAV 2.2 up to 93 will not work - NO motor mount bosses for truck mounts cast into block. After 94 they are supposed to all have them. Plus these have flat tappet cams, not roller cams.
94 & 95 Cav & truck - NO cam sensor hole - can not be used in 96 - 99
96 - 99 Has the cam sensor hole that can be plugged with a 3/4" freeze plug for use in a 94-95
98 & 99 Crank were supposedly different form other years. The timing notches for the Crank shaft possition sensor were moved so your sensor wont read correctly if you have a 94 - 97 2.2l.
i'm not sure, but i believe the heads are different. The truck probably has a bigger cam.
I have put a Cavalier head on my 97S10. The head came from a 96 cavalier. The only differenceis the water outlet. The Cavalier head had a metal plug in the hole where the truck outlet should be. I knocked out the plug and the water outlet bolted on. I didnt have to drill any holes in the head just the knock out plug. I have been running the Cav head now for three years. It cost $25.00 in a self service used auto parts place here in St. Louis.
1 - 16 of 16 Posts
