1 - 13 of 13 Posts
Well, I'm need 2 new compressors since mine are dead, whats the difference between the Viair 380 and the Viair 400?? Is it just the PSI? I'll probably buy them in the next couple of weeks... and also do you think an 8 gallon tank w/ 8 port is enough?? thanks
Beer, Bait and Ammo
what psi do you plan on running your truck? 145 or 200?
the 380 is 100% cycle as where the 400 is 33%
i have 2 of the 400's, and i want to upgrade to the new oasis.... :)
lol Just notticed 380 is 1/4" not 1/2" pipe fitting lol
thanks guys, looks like i'm gunna run w/ 2 Viair 380 compressors to fill up a 8 gallon 8 port air tank! I'm probably gunna run w/ 150PSI for my setup
former owner
380 is 50% duty cycle at 100psi and yeah, Doug, I noticed my 380 didn't have the 1/2" fitting you called for on that chart and meant to call you on it. I had the bushings already to make it work so it slipped my mind since it wasn't a problem for me.
bigjsp said:
don't you own 2 of them?
lol yea but when I typed that I must have missed a key :haha:
I need to fix that ASAP
If you're only gonna run 150, I would rather go with two 400's over the 380's. It will fill faster, by at least 45 seconds, on 110-145. Unless you plan on playing ALOT with the air system, I'd go with the 400's.
Tim, btw, the 380 is 100% at 100psi, and 55% at 200psi, based on Viair's website.
1 - 13 of 13 Posts
