1 - 20 of 46 Posts
SDimePimpin08
my interior is completely stock as of now and i hate the color of the plastic its like bluish black depends on the lighting so i want to paint that what kind of sand paper do i need to use to sand it and what kind of paint is used also is there primer involved if so what kind do i use thanks
Banned
theres a how to thread on here somewhere...
but the basic gist of it is:
sand the shit out of it with like 300 grit, then switch to like 600 grit.
krylon plastic primer, dry, wetsand with 600
krylon color, 5 coats. wetsand with 600 after the last coat
clear, 2 coats. wetsand with 1000
SDimePimpin08
Discussion Starter · #10 ·
alrite so tell me if this will be good sand dash with 100 then 120 then 200 then 220 then primer it with krylon plastic primer, let it dry, dry sand it with 600 then wetsand it with 600, then apply 5 coats of krylon color, let it dry, wetsand it with 600? or something less rough? then apply 2 clear coats, once dry wet sand with 1200.... done?
I started with like 100 grit and sanded till smooth , then i used 120 to get it a little smoother , then 200 for even smoother and then 220 to get ready for primer . Clean with soap and water . Spray primer on and look for bad spots and sand them out , then primer again , let dry and if it is real smooth go ahead and spray a coat of base , if not real smooth wet sand with like 1200 grit and then spray base . Let dry between coats until you get the desired amount of coats on there , no less than 3 or 4 coats of base . If looks kind rough wetsand with 1200 or higher and be real gentle not to mess it up . Then when that is done go on spray the clear coat on there , no less than 2 coats , i used 8 coats myself. Any other ?'s feel free to ask
I Like Fire....HaHaHa
What are you trying to do, give the kid nerve damage in his wrist from all the sanding?
Start with 120-160 (your choice)
Then step up in increments to 180, 220, 320, 400
Then start using filler primer and wetsand inbetween each coat with 400. Keep repeating this process until its baby smooth.
Then paint and clear coat.
If you want to cut costs down, you can use an adhesion promotor and Duplicolor paints and clear coats from Walmart. I've always stayed away from Krylon crap. Anyway, due to the size of some parts, rattle can will work fine. But its always best to use a gun. If you have the resource.
Let me give you a couple tips though, Interior look like shit when you paint only a couple parts. If you do it, go all the way and hit everything plastic. Makes a much more uniform look and people get the idea that you put thought into your project rather than grabbing a spray can and shooting it like the guys from "Unique Whips". That show pisses me off.
If you decide to start with rattle can and then opt to use a gun, paint shops can laser match your paint used and mix up a quart size batch for ya. Also, be sure ALL THE texture is sanded or prime filled out before paint. Nothing worse that shitty surface prep to make a paint job look like shit. With painting anything, surface prep is #1 almost over the paint itself.
1 - 20 of 46 Posts
