You can flush it out with a chemical cleaner the add regular antifreeeze.982.2sten said:be cause that's what came in it. Mines a 98. You can't put the regular in it after it's already had the Dex cool in it.
no you cannot do that... yes teh dex cool does become corosive. so just flush it out and use something equivalant... you cannot put reg antifreeze in a dex cool vehicle cause it will eat the seals. and jack it all up.developed said:You can flush it out with a chemical cleaner the add regular antifreeeze.
My mechanic said the DexCool will cause corrosive type problems and suggested I change over. He has nothing to gain by telling me as we are ol buds - used to race motorcycles together.
umm no if you leave the dex cool in there it will be a hell of alot worse on seals water pump radiator ect... dex cool is highly corosive and i as a mechanic have seen more problems with dex cool than the regular green stuff it has eaten the fins off water pumps gone through numerous gaskets and seals(especially 3.1 and 3.4 lower intakes) and yes you can switch to green coolant after running dex cool you cant mix the two together but if you flush the system completly once with just water and then with green coolant if will be fineLOW-LIFE said:no you cannot do that... yes teh dex cool does become corosive. so just flush it out and use something equivalant... you cannot put reg antifreeze in a dex cool vehicle cause it will eat the seals. and jack it all up.
You can put regular in it , all you have to do is completly flush DEX COOL out , done been through it with GM and that is what they told me .982.2sten said:be cause that's what came in it. Mines a 98. You can't put the regular in it after it's already had the Dex cool in it.
Yes, I deal with the same shit as you. We change the dex cool in 4.3's all the time at work, and 3.1/3.4's too.lilbluetruck98 said:umm no if you leave the dex cool in there it will be a hell of alot worse on seals water pump radiator ect... dex cool is highly corosive and i as a mechanic have seen more problems with dex cool than the regular green stuff it has eaten the fins off water pumps gone through numerous gaskets and seals(especially 3.1 and 3.4 lower intakes) and yes you can switch to green coolant after running dex cool you cant mix the two together but if you flush the system completly once with just water and then with green coolant if will be fine
OK joker - which one are you using?wayfastwhitey said:you're supposed to use anti-freeze??? who knew? That must be why it's so damn hot here in Texas!
actually neither...I run straight distilled water. Have been for years and yearsdeveloped said:OK joker - which one are you using?![]()
In theory that is the best medium to use. However, Prestone makes a new "green" antifreeze that is safe to use with both kinds. I would suggest you flush, but you don't have to with this stuff. You could in theory just run this, then after a while flush it again and switch to the regular stuff.wayfastwhitey said:actually neither...I run straight distilled water. Have been for years and years
I stand corrected. Was it 1996 then?superunknownmoto said:My 97 came with it from the factory.
maybe...my '96 came factory with dexcool....dumped that crap out as soon as I got it home.Dr. Nate said:I stand corrected. Was it 1996 then?
