Hey Guys,
Ok well i had 2 10" MTX 8000s. Well i blew one up this past weekend and thinking i had them not matched to my amp so i need your help. My amp is a sony xplod XM-2252HX....it puts out 225x2 rms. I am looking at Crutchfield and notcied the following subs all on sale. I have included the specs and would like opinions on which one to go with...if any. If you do not like the subs listed what would you guys use? I am planning on this setup lasting me a long time. Another thing, they are going in a regular cab s-10 (1990).
Kicker XPL X10c-4
polymineral cone
foam surround
frequency response 25-500 Hz
power range 75-350 watts RMS
peak power handling 700 watts
sensitivity 88.5 dB SPL
top-mount depth 4-13/16"
sealed box volume 0.8-1.2 cubic feet
Polk Audio GNX104
poly-mica woofer cone
MOMO-designed steel basket
2" voice coil
power range: 50-175 watts RMS each
peak power: 400 watts
frequency response: 18-400 Hz
sensitivity: 93 dB
top mount depth: 4-13/16"
sealed box volume: 0.66 cu. ft.
Sony XS-L1036
high-rigidity compound polypropylene cone
Santoprene rubber surround
frequency response 25-2,800 Hz
power range 40-250 watts RMS
sensitivity 88 dB
top-mount depth 4-15/16"
recommended sealed box volume 0.7 cu. ft.
Sony XS-L1046
aluminum cone
4-layer voice coil
power range 40-350 watts RMS
peak power handling 900 watts
sensitivity 88 dB
Thanks, Scott
Kicker XPL X10c-4
polymineral cone
foam surround
Polk Audio GNX104
2" voice coil
sensitivity: 93 dB
Sony XS-L1036
sensitivity 88 dB
Sony XS-L1046
aluminum cone
4-layer voice coil
sensitivity 88 dB
Thanks, Scott
