AVTekk said:A drill press to tap it? Or to drill it? You gotta drill a hole first obviously, and you want the hole to be as square as possible, so if your drill press is decent, set it up on that. I dont have a drill press so I do it with ye ole Milwakee! That thing will break your arms off, its great..
Anyway after you drill the hole, start tappin, but you dont wanna just run the tap into it, you gotta get it started, then turn it clockwise 1/4 turn, counterclockwise 1/2. This will cut nice and even threads and keep the cutting edge clean. Use LOTS of oil, and make sure the tap is square also..
:stupid: I just went and spent too much money on brass fittings to pay someone to tap my tees for gauges. Thanks Avcab said:Oh.. thanks for the info, AV..
I use a drill press, and I put the 1/8" pipe tap right in the drill chuck, and run it right inAVTekk said:A drill press to tap it? Or to drill it? You gotta drill a hole first obviously, and you want the hole to be as square as possible, so if your drill press is decent, set it up on that. I dont have a drill press so I do it with ye ole Milwakee! That thing will break your arms off, its great..
