1 - 20 of 32 Posts
ok i have air bags one my truck and when i let the suspension all the way down my truck leans to one side. I cant figure out what the problem is. it not hanging up on the tie rod end and the bags work right it just has a lean. i cant figure it out. it is on the drivers side front. i can get a pic if that will help you figrue out my problem.
Can't any body frickin read!!!!
To help you out..... take a pic of the front of the truck, so we can see. Here are your possible reasons tho....
tie-rods on frame. Control arms on frame. tire hitting wheel well. Bag cups too big and bag is fully compressing before you're on the ground.
do you have spindles?
how much of a lean is it. it could also be the tranny crossmember bracket (you know the triangle piece that holds the tranny crossmember in there) or the lower control arm is binding up in the frame where the bolts are
it probably leans to the driverside 2 inches higher then the pasengers side. it sucks and i cant figure it out
what really pisses me off it just started to do it about 4 days ago. it didnt do it before that i dont know if i hit something that could have knock it out of place and made it have a lean.
You're not really making any sense. You say the drivers side leans 2" higher. Does that mean the passenger side is higher, or the drivers side is higher.
when you lay it out, if the driver side is a little higher, it might just be that tranny crossmember bracket someone else mentioned.
if thats not it... i dont know what to tell ya other than ... look under the truck when it layed out to see what is touching th ground and holding it up.
No shit!!!!
Thats right on my way to/from gcc. I'm over at 59th and Union hills.
U gonna be around tomorrow around 11:30A or so? Thats when i get outta skool.
Discussion Starter #15
I WILL BE HOME FOR 11:00 AM TO 1:00 AND THEN I GO TO SCHOOL BUT I GET OFF SCHOOL AT 8:00 AND I WILL BE HOME AT 9:30
I got school till 10:30 tomorrow night. I have class from 10-11:15A, then again from 5:45 -10:30
I get off work on wednesday at 3. got any time then?
1 - 20 of 32 Posts
