im droppin the front 3"....is it better to do 2" spindles and 1" coils or simply 3" coils....coils would be the cheaper one though, so hopefully they are just as good with performance and ride?
The less travel you have the worse the ride will be. 3" coils simply remove 3" of travel from your suspension, whereas a 1" coil is only 1". Add spindles and you drop 2 more inches without affecting the ride whatsoever. so the best ride will be from the spindle, spring combo. I suggest the spindle drop since you might get a wild hair in the near future and want to bag your truck and you're gonna need them.
