Actually, I am referencing the 4600 series designed for the S10. I had trouble finding the ZQ8 shocks back in 2012, so I bought a set of the 4600 and they've done well for me. They a firmer ride, but the truck handles curves nicely. It can get a bit rough on bad roads, but I tend to like performance over comfort as long as it's not too harsh.Are you talking factory ZQ8 Bilsteins? They've been discontinued from what I've seen. I found one front on eBay, but nothing else in the searching I did a couple days ago. Might be worth calling up Bilstein to see if they might be able to reproduce them (even though it was a factory only part) or make you a custom shock with the same valving. It was a great shock for the ZQ8 suspension.
I would take it to a frame shop that does big trucks and have them evaluate it and tell you the best way to repair it. If you can find a donor I would swap the entire frame rather than try to weld a section on. Judging from how the cab is tweaked I think the frame damage runs a lot farther forward than you think.I stared at damage on my rig, and then made frames for a 3 pc "Persistance of memory" canvas prints. Then I went outside and made a damage video...got depressed and ate muscle relaxers + cookies...here's the video lol
I was thinking try to find an exploded z, swap my 47k motor and 200mile trans, interior, be done with itI would take it to a frame shop that does big trucks and have them evaluate it and tell you the best way to repair it. If you can find a donor I would swap the entire frame rather than try to weld a section on. Judging from how the cab is tweaked I think the frame damage runs a lot farther forward than you think.
That would work as well.I was thinking try to find an exploded z, swap my 47k motor and 200mile trans, interior, be done with it
Edit, yeah long day, bit dumber than normal, yes my cab is good too, so YES, what you said: find roller
I decided to tackle the rear axle leak at the pinion on my S10 this weekend. I originally noticed it leaking back in November, but I've had too much going on to fix it until now, plus I had another vehicle I could drive in the meantime. Also, I was a bit hesitant because I thought I was possibly needing to rebuild the axle; I have experience (my Dad and I despite neither of us being mechanics successfully changed the ring and pinion on my old S10 from 3.08 to 3.42 about 20 years ago), but I really didn't want to take on that big of a project right now. It turns out the seal was actually pretty easy to change, and apparently the leak was coming from the sealant behind the washer breaking down over time, not the pinion seal. I currently have 266,000 miles on the truck, so I changed the seal anyways.
Pinion nut removed after scribing the parts for reassembly.
Notice how the housing is dry at the pinion seal.
Back side of washer.
Back side of the yoke is mostly dry.
Front side of the yoke. I'm not sure what the white sealant is, but it was very brittle. I used Permatex black RTV on the ends of the female splines when I reassembled it.
Pinion nut reinstalled and tightened an extra 1/16" past the original mark.
Everything reassembled. I also checked the cap on the end of the vent line to make sure it was not blocked.
When I finished, I wiped down most of the axle surface to get rid of the oil. Unfortunately this spot that looks like a weld appears to be seeping oil. This was a few hours after I had cleaned it and took it for a drive. Ah, the joys of an old vehicle: fix one problem to find the next issue.
I have 96K on this set and though they don't bounce bad they seem a little unsettled, like they're a bit more jittery with bumps. Also, though I've never really had bad wheel hop, the last year or so it has been more noticeable. I figured if I'm needing to get the truck aligned and the shocks are near the end of their use, I should be proactive and replace them.
So far I've only been able to find the rears in stock at Summit. The fronts say special order, arriving 2-14-22, but when I called they couldn't verify for me if that meant they were expecting new stock on 2-14 or if I ordered them they would be in on the 14th, or if that was just a generic future date and they were waiting on Bilstein and really didn't know when they would be back in stock. I'll wait until the 14th and if Summit still doesn't have an answer I may give Bilstein a call. That's a good idea, thanks!
I ended up not calling Bilstein. The Bilstein shocks (24-187428) I was needing showed to be in stock at Summit last week so I ordered a pair along with a set of the rear shocks (24-016810). They arrived last night, so hopefully I can find time to install them in the next couple of weeks. FYI, these are the 4600 series shocks designed for the S10, but not the ZQ8 specific shocks. I've liked them on my ZQ8 truck, and honestly it has been so long since my original shocks wore out that it's hard for me to compare them unless I drove them back to back. But I believe these are a bit stiffer.If you call them up report back how it goes!
