Finally got my rotten frame 01 2.2l sold, got a whopping $100 for it. By far it was the worst loss I've ever taken on a beater but sometimes that is just how it goes. The 00 4.3l 4wd is somehow working great despite eating a dizzy cap screw a month ago. Honestly, I've been pushing it as hard as I possibly can every single day just to see if the motor is going to let go and it simply won't. About the only thing I'm not doing is high rev launches due to the fact both motor mounts are shot and only the trans mount (and driverside ratchet strap) are the only thing keeping the motor from moving around. Otherwise, it sees redline shifts multiple times per day, has hit the 95mph governer a few times, and likke a loyal soldier it does it all without complaint. Gotta love the 4.3l's reliability.
Besides ragging the heck out of the truck I've done a little work improving some things. Replaced the nonfunctional reverse camera that I installed earlier with a new one that wires directly into the old school pioneer x2800bs my stepcousin gave me. Removed the clutch fan in preparation for a junkyard electric fain install (fan was in the always roar failure mode), thankfully with the weather being chilly it has no issues overheating with no fan. Bypassed the AC since the clutch bearing is failing in a bad way using the 840k6/remove idler trick, and might simply remove the rest of the system if the motivation to do it comes up. Picked up a flux core welder and went over the leaking muffler flange again to plug up the bits my $60 stick welder failed on along with patching a couple of pinholes in the muffler.
Annoyingly after I installed some cheap 9005 leed drop-ins I lost my DRLs, I'm thinking the low voltage that the drls run is too low for them to work but I guess I can just accept it as an inadvertent DRL delete setup. Considering the output of those appear to be somewhat less than the led 9006s that I have I might see about doing the quad light mod but on the low beams, I mean its not like the glare will be any worse for others than it already is running LEDs in a headlight that wasn't designed for them.
Here in a day or two I need to do a tire rotation, noticed that the rear right tire has significantly more wear than the other 3 despite the truck being equipped with a gov locker. Also should probably pull the dif cover and see why the damn gov locker aint working/possibly modify the clutch weights to allow for higher speed engagement.
