I'm not a cop, who are you trying to BS? 🤣It wasn't intentional...
😂 😂 😂 I'd like to have an 8.5 before punishing my truck. Art Morrison is just a few miles away. I could take a 4X4 rear to him to be narrowed and different ends put on the tubes. He did a 12 bolt for my V8 Vega. I'm sure the price has gone up a bunch.I'm not a cop, who are you trying to BS? 🤣
I looked into that myself since Mark Williams is here but it is cheaper to go the way I did. You could always do a road trip down here this spring and buy one of the 2 that were left after I got mine.😂 😂 😂 I'd like to have an 8.5 before punishing my truck. Art Morrison is just a few miles away. I could take a 4X4 rear to him to be narrowed and different ends put on the tubes. He did a 12 bolt for my V8 Vega. I'm sure the price has gone up a bunch.
Do you recall or know what the gear ratio of them were?? Any left over issues should be taken care of by then. Chances are pretty good they'd be gone by then.I looked into that myself since Mark Williams is here but it is cheaper to go the way I did. You could always do a road trip down here this spring and buy one of the 2 that were left after I got mine.![]()
From experience, the housing is all you really want. Axles are probably worn at the outer bearing and like has been mentioned a trutrac is a great update, which includes the carrier. New bearings and seals are about $100. Yard probably charges less for just the housing too. You're only really out the cost of the gears without buying the whole thing.1 axle missing
3rd member gone
Gears removed
Bearing caps scattered
I have no use for a unit like that...
They still have one left from a 2003 with 70,000 miles and 3.42 gears. There are others around too so I will do a search in your area and see what I can find.Do you recall or know what the gear ratio of them were?? Any left over issues should be taken care of by then. Chances are pretty good they'd be gone by then.
From what I could find out all 2wd Blazer disc rears came with 3.42 gears. I changed mine to 3.23 figuring that with the extra torque it wouldn't make much difference and might help fuel economy. with my 4.3 I can't tell much difference in performance just my speedo reads 65 I'm actually doing 68 so I'm thinking I should have gone even taller.Do you recall or know what the gear ratio of them were?? Any left over issues should be taken care of by then. Chances are pretty good they'd be gone by then.
I'll call you tomorrow..From what I could find out all 2wd Blazer disc rears came with 3.42 gears. I changed mine to 3.23 figuring that with the extra torque it wouldn't make much difference and might help fuel economy. with my 4.3 I can't tell much difference in performance just my speedo reads 65 I'm actually doing 68 so I'm thinking I should have gone even taller.
If you are sure you want it I could go pick it up for you and store it until you can come down to get it. I could even prep it like I did mine and we could swap it out here.
At this time I have no space at all for extra parts around. Trust me I normally pick up parts that are useful.From experience, the housing is all you really want. Axles are probably worn at the outer bearing and like has been mentioned a trutrac is a great update, which includes the carrier. New bearings and seals are about $100. Yard probably charges less for just the housing too. You're only really out the cost of the gears without buying the whole thing.
Did you try repacking the bearing? Doesn't take very long to do, and you can make sure the nut isn't over tightened.Turns out the annoying squeak that I've been ignoring was my wheel bearing failing from either under/over-torquing the axle nut or simple old age. Got the part ordered and now I'm hoping and praying it'll hold together for just 2 more days/2 more 30 mile morning drives without failing. There's only approx 1/16-1/8in play at the very edges of the affected wheel when jacked up and the axle stub/nut only feels luke warm after a solid 20 miles at 45mph so hopefully it should be fine for just two more days.
Nope...good luck.Can that be done on a 4wd hub assembly?
It seems right it's 1 turn from center to lock right or left the old one was 1 & 3/4 turn from center to lock either way. The old one the alignment shop try to adjust it but could not get all the play out of it. I bought the old one from AutoZone back in 2017 so it don't surprise me that I went bad.It probably has just as much wear as your old one but with an adjustment and a re-seal. Wouldn't be surprised if it's not a ZQ8 box as advertised either, they usually aren't.
