1 - 20 of 76 Posts
03 GMC Sonoma SLS & 04 Chevrolet Blazer Ls
Replacing upper and lower control arms on my 04 Chevy Blazer also adding Bell tech 4202 1in drop springs with new MOOG spring insulators and shocks. And if I have time replace bushings and door pins in both doors.
Just got done with the upper and lower control arms. This 04 Blazer was a virgin. The control arms were not ever replaced. it fought me tooth and nail all the way. Then my spring compressor broke it gave me a Jesus moment :eek:. What a beautiful day it was.
Replace door speakers and dash tweeters with Pioneer TS-D65C and replace rear speakers with Pioneer TS-D69F . Forgot how fun it was to replace the rear 6X9s on a two-door Blazer.
Had to replace my HVAC box today two 2 of 3 doors inside were broken thanks to the defrost vent falling to pieces and going down inside and blocking the doors. Had an extra one from my 03 Sonoma fit perfect.
Broken
350355
New used one from Sonoma.
350356
Replaced both exhaust manifolds. Tried to just replace the studs in the original exhaust manifolds but they all broke off into the manifold. Also replace driver and passenger motor mounts. both of them were ripped in half. And started on my custom steering shaft.
Why did you take the top off of your center console??
There is something wrong with the wiring harness that plugs into the shifter. I swapped the shifter still had the same issue so I swapped the harness and so far no more issues.
2 10mm bolts and a couple of screws and the entire console lifts off.
Discussion Starter · #11 ·
Put the rebuilt 4L60e in today started the run the 6-AN trans cooler lines. Couldn't finish all the lines waiting on fittings to show up.
Premium Member
I saw these on the Dakota Digital web site and thought hmm "I like buying good gifts for my mistress lol nobody will know but me hand her eheheh!" I came across this new direct fit option. I'm glad that they make something else for the first gen S-10s. The only thing I don't like is that the turn signals are small and in the MPH gauge. Overall I think they will be nice fit.
Discussion Starter · #13 ·
Going to remove the orifice check it for garbage if all good replace orifice and vacuum
system down and refill the AC and replace driver side window motor.
Discussion Starter · #14 ·
AC all done well it's nice and cold 43° at idle at center vent. Outside temp about 90° with 36% humidity. And drivers side window motor done.
Discussion Starter · #15 ·
Me and my Wife remove driver seat today took it apart and stitched the lower pad where the seam was coming apart on the outer edge. Also fixed back lumbar support rod were it broke at the bottom like all of them do. Clean carpet and headliner. And I ordered some Lloyd floormats. The metal they use in these seats is garbage even brazing it will blow a hole in it easily.
Discussion Starter · #16 ·
Finally have the catalytic installed now taking it for a nice long drive at 55 to set monitors. Then I can go get my smog done and get my tag.
Discussion Starter · #17 ·
Finally all done got the monitors to finally set after 4 hours and 100+ miles. Pass smog and got my tag. That thing did not want to set the catalytic monitor. And driving 55 on the freeway it's definitely a death wish.
Discussion Starter · #18 ·
Right when you think your ahead you get kicked backwards. After driving the blazer for a while started hearing this like squeal chirp so I thought it was the serpentine belt. So I went and bought a new serpentine belt kit replaced everything still chirped and squeal and it sound like it was coming from the alternator so I replaced it. It's not the alternator turns out it's the water pump. It's not leaking but I'm going to replace it this weekend that chirp squeal is driving me nuts.
Discussion Starter · #20 ·
Okay today I did upper and lower intake gaskets also replaced injectors and replace distributor (aluminum) and I added two thermostat switches into the intake. Low speed turns on at 180 shuts off at 165 and high speed turns on at 200 shuts off at 185. And I did relays and wiring for electric fans.
1 - 20 of 76 Posts
