Just curious if you guys knew any place I could get a 350 TPI? I tried a few local junkyards and came up empty. I live in northern IL and want the same era 350 as a 92 4.3TPI? Can I get this out of a truck? or should I just look for a Camaro? Any differnece?
:dunce:
I have 305 TBI out of 90 camaro 70k on it girl owner just replaced with 92 TPI nothing wrong with the motor she neds more speed
you can get almost any chevy 350 and put the TPI or TBI fuel injection system from a camaro on it ...(with the exception of vortec engines). the only problem you may have is the 2 intake bolts in the center are at a slightly diffrent angle, but you can get a dremel tool and hog the intake bolt holes out to fit an earlier head pattern. Small block chevys have not changed too much since 68. but they did make minor changes like center-bolt valve covers, one piece rear main seals, roller lifters, and the intake bolt hole angle in 86.
