1994 GMC Sonoma 4.3L V6 5 speed
Got a weird problem with my 94 Sonoma’s turn signals. My passenger side turn signal will illuminate, but will not flash, no matter if the headlights are on or off. When I turn on the flashers, my passenger side front side marker light & tail light will flash, but my passenger side right bumper light will only illuminate, not flash. The driver side is completely fine. What could be causing this?
Discussion Starter #2
I should also mention that I checked all fuses, and everything was alright.
Check the bulb and the grounds on the inside if the rad support. Could also be a rusty bulb socket.
a mintruck is never done
there are more grounds on the frame rail about a foot from bumper i think passenger side. look for a green block, could look black with a line of wires going in it there all ground bad to break some at it
A 94 would not have had the green ground junction blocks. Those a 98+
