Hi! I have a 2001 s10 w/s 2.2 5spd manual, I recently had the transmission guts replaced (2345 gears, clutch, slave cyl, and all the other goodies).
I got the truck back Friday, and today (Saturday) I'm having a weird issue.
The issue I'm having is when I turn the ignition on my front right turn signal comes on and stays on. It does not flash when I use the turn signal. However when I use the turn signal the right rear light comes on and stays lit.
When I use the left signal everything on the left works fine. I replaced the flasher/hazard relay behind the glove box to try and see if that was the problem but no luck. Due to work I won't be able to bring it back to the shop to have them look at it until Tuesday. Any ideas?
Thanks so much
Thanks so much
