1 - 1 of 1 Posts
If you are looking to clean up/complete your air ride system, this is what you need!! Water traps are a VERY important, and, sadly, overlooked part of many air ride systems. As your compressors build air pressure, moisture builds. You can run a water trap between your compressor and your tank. That way the moisture that your compressor built up, will not be setting in the bottom of your tank, getting into your valves, etc. 317-856-1810 http://store.gaugemagazine.com/water-oil-seperators.aspx
1 - 1 of 1 Posts
