I have a 1991 s10 with the water pump about to go out.When i change the pump do i need to put sealer on the gaskets? get at me s10 forum..
Yea, the sealer goes on the water pump side of the gasket...not on the block side...if yours is a 2.8 be careful if it has torx head bolts on it...I stripped one of mine out and had to grind the water pump off to get to the bolt to get it backed out.
i just recently replaced my waterpump, there are no torx bits besides one large one for the tensioner. I put sealer on both sides of the gasket to be sure...make sure u scrape the old stuff away real good. but mine works great no leaks
peace and big boobs to u
Nope, they are 3/8" bolts. Also the pump's rotation is counter clockwise.
I have used this one for at least 4/5 years along with a this GM part 10220957
It is a 170 * t-stat. Works great with all the crap I put my old ride through.
http://www.summitracing.com/parts/BRA-1774/
damn!! $75 bucks, i have a $32 dollar autozone special thats been working fine for over 10 years and the engine runs at 180*
Part Number:
CWP-715HD
http://www.autozone.com/autozone/parts/1991-GMC-S15-2WD/Water-Pump/_/N-itw0kZ9pd8f
i saw what you did there!
im scrapping all kinds of good one year old water pumps in the morning on this load of scrap. no one wants them. one is still evne int he box.,
i never use sealer i jut put the gaskets on dry.
ppl worry too much, they never leak there anyways,
