The top readiator hose is leaking and I am replacing both, While I am there I am replacing the thermostat also. Should I replace the waterpump? I just got the truck a week a go and I am trying to tune it. I did spark plugs, wires, fuel filter and air filter so far but I discover the leak while I was replacing the wires. The truck has 100400 miles and it runs perfect.
Thank you
I just did mine on my '01 and it was a piece of cake where it's located. 4 bolts and the lifetime warranty part was around $20 I think from Pep Boys. Mine has 225,000 on it and it started leaking from the weep hole.
I am goingt to wait until it fails then. I can do it when the truck is close to 200K and I can use the money for a set of 2" drop spindles.
THank you
It's "Neanderthal"
You might as well leave it, it's real easy to get to. Drop spindles for $20?
