1 - 18 of 18 Posts
I cant win for loosing.
You guys ever heard of them...VW uses them on the turbo diesel jetta. A guy who works with me has one and is about to upgrade his turbo, and he wants to give me his to use on my dime.
They spool so damn fast. He goes from 0 to 23 psi in a 400 rpm span. I have seen it...
What would it take for this to work on my truck besides the obvious fabrication. Ill only be using it for 7 psi though...and I have a 4.3
yea, they put them on daytonas in the early 90's, its not really new technology. Its called Variable Nozzle Technology. Generally they are small units and if hes running 23psi either his gauge is broke or the turbo wont last long, unless its an aftermarket. Actually i think the newer Ford diesel trucks use them, or maybe its Chevys, cant remember. It uses vanes inside the turbo to control the spool up and usaully has a smaller compressor wheel. Most people dont use them for performance cause they use solenoids to control it and have a weird wastegate actuator. They are a little harder to mess with. Slow spool usaully is the cause of another problem or a mismatched turbo.
It would work if you can get the vacuum stuff right. Normal turbos usaully have one vacuum line to the wastegate, or if you want full boost that the wastegate will allow pull it off and watch the boost fly! Then you have a set a ashtrays. Seems like kinda small for your engine though, but i like when people try things different.
I knew how they work but thanks for the great information for those who dont know. The boost he is getting is reliable for TDI Jettas they do it all the time. Anywho, I was just wondering what would be involved in getting one to work on a 4.3 since they spool so damn fast the power would be low in the rpm range makeing for a great pulling engine for towing stuff...like my bass boat!
if thats all you were looking fo it would work good, heck any turbo VNT or not off of a 4cyl would spool super fast on 6 cyl caus they woul be small. looking for just 5 psi or so it would work good. Anything more than that it would become a bottleneck on a larger engine. I would give it a shot, remote mount it and see what happens, just get an a/f gauge and boost gauge. Take it safe and you would only be out a tailpipe.
yeah but the only problem is that i dont know what all needs to be hooked up to where...I know they run off a vacume system but where does that hook into the engine,and what do i need to do for oil and all that...
Nitto1320 M O D
My dad had a GLHS Omni which I believe used the VNT turbo... We built that little car with the old mopar stage 2 parts, but left the stock turbo... After 2 quarter mile runs at 22psi, the turbo ... well lets just say it only hold about 4 psi now.. Those little turbos cant handle too much high boost, so make sure you check the compressor wheel for play before you install that on your truck.. As for mounting it... the front of the engine on the passenger side has the most room (look at a GMC syclone and mount it very similar to that).. Tap into your oil pan for the oil return and use the pressure sending unit with a T fitting to oil the turbo and run the gauge.
Any soucre of vacuum would work. Hooking straight to the manifold would work. Manifold pressure should hold boost at around six psi or so, but I would get a manual boost controller so its controllable. Look for one on ebay, one of those cheap $20 ones will do.
"factory freak"...
the VNT turbo (Turbo IV engine) was only used on a limited number of CSX Shadows, and a few Daytonas, i believe... very rare.
never factory installed in Omnis. the GLHS was basically a Turbo II engine, which was intercooled, with the std. turbo with a conventional wastegate.
many turbo Dodge owners, myself included, have used the factory turbos at or above 20 psi for extended periods of time, without failure. of course, the turbo has to be in good condition to start with to handle this kind of stress.
and you cant just hook a VNT actuator to manifold pressure and expect it to work right... its a dual chamberd actuator, and must have duty cycle solenoids in the lines, along with proper computer programing to control them, in order to make it work correctly...
i may wrong, but i think the 04, or 05 Duramax engines have started using a VNT type turbocharger. which would of course be bit too large for a mild 4.3 anyway.
honestly, just drop the VNT idea. a std. T4 from a GN Buick would work quite well for a mild 4.3 turbo project...
Discussion Starter #11
yeah...i found all this out as well today from the guy who has the turbo...and gn t4s are hard to come by. all though by the time im ready to do this I have a friend who will be upgrading to a bigger turbo in his national that may part with the stock one...hmmmmmm
thanks for the help guys...even though my idea was shot to hell...i guess it could be done but it would take way to much money for the gains involved...
Just found this, they explain how the VNT could be controlled if you want to experiment. Its for the VNT25 which is what chrysler used, but may help. From www.thedodgrgarage.com respectively.
EXPERIMENTING WITH THE VNT25 VARIABLE NOZZLE TURBOCHARGER
By Andrew E. Johnston
Technical Support Manager
Garrett / Bendix Heavy vehicle Systems Group
INTRODUCTION
The Garrett Variable Nozzle Turbo (VNT) is one of the most advanced and interesting turbochargers that has ever been offered in production. Unfortunately the first production application of a VNT on the Shelby CSX was shorter than expected, and Garrett was left with around 1200 of these turbos. Garrett decided to make these discontinued units available as surplus at a reduced price for race and custom installations. This article discusses some basic theory and application notes for this unit.
BASIC THEORY
Matching a turbocharger or supercharger to an engine that only runs at one speed and load would be easy. Designing a system that will achieve the optimum boost pressure under all conditions is much more challenging. Ideally, the boost could be controlled smoothly and efficiently at any speed or load. Achieving this goal requires an air compressor with a variable power source.
Superchargers are limited in this respect because they must obtain their power directly from the crankshaft.
This has two disadvantages:
1) They are directly linked to engine speed, not boost requirements, making it difficult to turn on "half way" at part load.
2) It consumes crankshaft power directly (typically 30-60 % of the engine output hp!)
Mechanical variable speed drive systems have been tried, but they are expensive, big, hard to control, and inefficient. Simple superchargers systems are typically belt driven and are controlled by a combination of on/ off switching and throttling, either of which are a compromise under part load conditions.
Turbochargers on the other hand, obtain power to drive the compressor from a small gas turbine that extracts energy from the hot exhaust. This is much more efficient than taking power from the crank directly because it is using thermal energy that would otherwise be wasted. The additional backpressure only consumes a fraction of the power that would have been required from the crankshaft The high speed of the turbine allows the use of an efficient high speed centrifugal compressor without the need for expensive gears or drive systems.
The turbine also has an important advantage because it is not directly linked to engine speed. The turbine power output tends to follow engine load, which is one of the reasons why most turbo diesel engines do not need any boost limiting controls. The compressor power, and therefore boost, can be easily controlled by changing the turbine power if desired. One way to control turbine power is with a wastegate. A wastegate is simply a valve that allows some of the exhaust to flow around the turbine instead of through it. This limits the turbine power at high speed when more exhaust energy is available than needed to drive the compressor. A wastegated system allows the use of a smaller turbine that is sized to make boost at low engine speed.(i.e. the wastegate is closed) The wastegate will prevent the turbo from overboosting at high speed as would otherwise occur with a small turbine.
This system offers smooth and simple control, but still not optimum. The exhaust energy bypassed around the turbine is wasted which is why they are called wastegates. At high speed a turbine with a larger nozzle could use all the exhaust flow and make the same power with less exhaust backpressure. The ideal system would have an adjustable turbine nozzle that acted like a small turbine for fast response at low speeds and a large turbine for maximum power and efficiency at high speeds . An adjustable turbine could also be opened to minimize backpressure when boost is not needed. This would provide the ideal boost with minimum exhaust backpressure under all conditions.
THE GARRETT VNT25
Garrett has developed a turbocharger that does this. Instead of using one nozzle to accelerate the exhaust gas towards the turbine wheel, it has a ring of 12 variable vanes. As the vanes are rotated, they change the area of the nozzles that the exhaust must pass through. The smaller the nozzle, the faster the gas velocity, the more turbine power, the more boost. At the other extreme the vanes can open fully when boost is not needed, with the resulting reduction in exhaust restriction. The concept of the VNT has been around for a while, the trick was to make one where the vanes would not stick when run for thousands of miles without lubrication in a hot exhaust environment. Garrett spent considerable time in r&d to arrive at the special combination of high temp materials and manufacturing processes for the vanes and mechanism to ensure reliable operation.
The VNT is mated with a low inertia rotating group and an efficient centrifugal compressor to achieve the goal of a truly adjustable boost system. In addition the system efficiency is improved at high speed due to the reduction in backpressure compared to a wastegated system.
CHRYSLER APPLICATION INFORMATION
From an application standpoint, this turbo was used on the high output intercooled 2.2 liter four cyl. rated at 175 hp. The Chrysler engineers utilized the engine computer to take advantage of the additional control afforded by the VNT. The computer controlled the vanes by adjusting the pressure fed to the spring and diaphragm actuator. This system used a standard catalytic converter and exhaust system. The turbo limited boost by action of the vanes and did not use a wastegate.
CUSTOM APPLICATIONS
So, What engines are candidates for a VNT 25? The answer is not so much engine size, but power. This turbo should work on an engine that can produce 150-200 hp with 8-15 lbs of boost. I am aware of a 1600cc VW installation that is very responsive. Twin VNT's on a 400 hp Porsche should be outrageously more driveable than the stock big single turbo. Another candidate for a twin would be a Buick 3.8 liter V6. This turbo should also work on high rpm 1 liter motorcycles, but the turbine housing is fairly large from a packaging standpoint. Remember that these application suggestions are just that, not guarantees. These units have standard late model Chrysler turbine and compressor housing connections and use standard Chrysler gaskets. As far as using the VNT on a custom application, the flange dimensions and bolt patterns are not the same as any other turbo, but adapters can be made with the dimensions shown
OIL SUPPLY
This turbo needs .3 gpm of oil @ 30 psi. minimum at full power. Any oil that you can use in the engine will work for the turbo. The oil drain uses one bolt and seals with an O ring. A flat flange with a gasket will also work. A .5 inch minimum inside diameter oil drain is recommended and must be within 30 degrees of vertical with no "sink traps" that will allow oil to puddle.
CARBON SEALS
The unit uses a carbon seal and therefore be used with a carburetor upstream in a draw through installation,although the Chrysler was fuel injected. Except for the VNT turbine, this unit is very similar to a standard Garrett T25. The compressor, bearings and seals are interchangeable with T25 turbos.
WATER CONNECTIONS
The water cooling is intended for passenger car applications where the turbo is bolted to a heavy cast manifold withlittle airflow and many miles of stop and go service. The water cooling is not needed on a race car that isn't driven daily. Likewise, the water is not needed when the turbo is mounted on headers that don't store heat like a casting can. The water fitting is designed to mate with a steel tube flare nut. These can be removed and a different adapter can be threaded directly into the pipe threads and in the housing. Remember that the water is only for cooling during shutdown, the oil cools the bearings when the engine is running. When the engine is shutdown the heatstored in the cast exhaust manifold "soaks back" into the turbo causing the water in the center housing to boil.
When this happens it is important that the bubble that forms can escape upwards causing water to flow in from below and allowing the cycle to repeat itself. The upper hose should connect to the engine at a higher point than thelower water connection. The water flow direction while the engine is running is not important. It is when the engine stops that the boiling occurs.
TEST INSTALLATION AND VNT CONTROL
To determine the ease of controlling the actuator and to discover any installation problems in general, the author installed a VNT25 on his sandrail (Dunebuggy). The engine is a 2 liter German Ford. To keep the installation assimple as possible, the turbo was mounted on an old Roto-Master cast iron manifold that was intended for a T04B. Drilling the bolt holes out to 9/16" allowed the turbine to fit 3 of the 4 bolt holes and sealed acceptably for the test. The turbo pressurized a Motorcraft 121 two barrel carb in a simple "blow through" configuration. The pressure side (small tube) of the VNT actuator was connected to the hose fitting in the compressor housing.
The results were instant boost and easy wheelstands in 1st and 2nd gear. The vanes were closed at idle and it was very quiet, even without a muffler. The VNT limited the boost to 12 psi without any further controls during thequick " around the block" bonzai runs. (This control point is a function of engine size and flow and may be different for your application.
The addition of paddle tires and some steep dunes, however, changed things. The engine was not fully loaded onsuch a light vehicle on flat pavement. On a steep incline the boost would rise to over 20 psi as the engine became fully loaded. The solution was to install a conventional wastegate to control boost when the flow range of the VNT was exceeded. This is recommended for all VNT applications.
BOOST CONTROLS
Chrysler did not need a wastegate because the backpressure of the stock exhaust limited turbine power. TheSandrail used a very low backpressure 2.5" exhaust system. The Sandrail installation simply ran a hose from the compressor housing to the pressure port of the actuator. Do not make the mistake of assuming that the larger 1/4" port is for pressure because it is the same size as the fittings on the compressor housing. The 1/4" port is for vacuum. The smaller 3/16" port is for pressure. Pressurizing the vacuum port forces the vanes closed at all times.
They will eventually plug up with carbon, causing the " potato in the tailpipe" effect. If your engine runs poorly or won't start again after your first test run, check the actuator hoses. The boost setting can be mechanically adjustedwithin a limited range by shortening the rod length. Make sure the diaphragm does not bottom out before reaching the full stroke. It can also be adjusted with an electronic adjustable boost control system that is designed to control a conventional wastegate.
A pressure regulator can also be used as a "boost over boost" control to raise the actuator pressure control point just as it is used on a wastegate. In a nutshell you run a controlled amount of boost to the "wrong" side of theactuator to cancel out part of the pressure on the boost side. Each psi put on the back of the diaphragm raises the boost setting by 1 psi and so on. This is plumbed by hooking up the actuator pressure port to a boost signal (i.e. the fitting on the compressor housing) directly as usual. Then hook up a second from the same boost signal to a pressure regulator and then to the vacuum side of the actuator. Setting the pressure regulator to 1 psi raises the boost `1 psi etc...
In an off road or race only application this simple system will suffice. As a minimum a " part throttle open" controlcan be easily achieved by connecting manifold vacuum through a check valve to the vacuum side ( big tube) of the actuator. The check valve is to block boost. To prevent any pressure from being trapped between the check valve and the actuator, a .030" bleed orifice to atmosphere should be used. This will open the nozzles when vacuum is present at idle and part throttle.
This has some important benefits:
1. It cycles the vanes every time the throttle is depressed which helps them stay free of carbon.
2. It prevents excessive EGR due to higher then normalbackpressure which affects idle quality.
3. It improves fuel economy by eliminating backpressure caused by the turbo.
4. It prevents part throttle boost which heats the intake air unnecessarily.
5. It provides a more linear feel to the throttle pedal position.
GENERAL INFORMATION
There are a few very important points concerning these turbos:
1) A common question is: Do you have one with a different compressor wheel, or A/R? The answer is no We only have this particular unit available. ( p.n. 465599-6)
2) These turbos have been discontinued and once the 1200 are gone that is it. Chrysler reportedly has quite a few for the Shelby's, but they may cost more when purchased through a dealer.
3) As far as emissions are concerned, this turbo is only legal on the 89 CSX, 90 Shadow, 90 Daytona, & Lebaron VNT's…………………………………………………………….END
Vortech power not Vtec!
skinnyg said:
Generally they are small units and if hes running 23psi either his gauge is broke or the turbo wont last long.
I got a VW TDI and my car runs 23 psi and spikes to 30psi all day, and its not only me, its 1000's of people that do it everyday. Go check out TDIclub.com if you dont believe me. A few people on this forum has seen my boost gauge and can verify that also. Its a VNT15. I plan to upgrade to a VNT17 soon.
Here is a very good link about VNT turbos and how they work.. http://www.technologie-entwicklung.de/Gasturbines/VNT15-Turbo/vnt15-turbo.html
Discussion Starter #15 (Edited)
Damn dood I didnt even notice that you posted that .gif. Thats badass.
Since I stopped posting on this thread I have learned alot more about these turbos, adn found out from the engineers at garrett that there is no reason why we cant use these on gassers, if we keep the temperature in control. IE...remote mount
Im gonna yank a digital thermometer from work, and go for a spirited drive and see what i can get the pipes to heat up to at the point where I want to put the turbo.
You still have to run all the other normal shit like, a scavenging oil return pump, water cooling lines, blah blah blah...but can you imagine a 4.3 at idle going to 7-8 psi and 600-700 cfms in less than 500 rpm. Smoke!
Oh and I have since decided that an upgrade in turbo would be needed as the VNT15 off the jetta is cast into the exhaust manifold, and just waaaaaaaay to small, and will be using the turbo from a chevy duramax. Thatll push plenty of air for me to think seriously about upgradeing to a 2114 and some 50 lb injectors, and an intercooler. Then its up the boost!!!!! Going for 350 at the wheels.
the chevy duramax might be too bog for the 4.3 dont you think? You can also try the VNT17 or VNT20. I think they even make bigger one. My brother is going to put a vnt17 on his Golf soon. Keep me updated.
Discussion Starter #17
Well the VNT17 and 20 will deffinitly be too small i think, but Im open for anything really. Does anyone have specs on the VNT20 like a/r, and how the vanes are controlled.
Discussion Starter #18
Found out today that I cant use the turbo from a duramax..the vanes are controlled by oil pressure via the ECM, and it cant be easily retrofitted...Garrett however has a VNT turbo line that the vanes are controlled by boost and vacume so that is the route I will have to take.
1 - 18 of 18 Posts
