Here's the picture:
Used motor swap in my 86 s-10 w/2.8, dropped in an '87 2.8 . I got to run the motor before I bought it. Checked out fine.
I installed the motor and experienced Tremendous vibration at idle and going down the road. I went to the chev dealer and they said the mounts were hosed.
OK, now I have BRAND NEW motor mounts and a BRAND NEW trans mount, all of which were totally shot. The vibration still persists. It is terrible to endure for my one hour commute each day.
I changed the harmonic balancer because it had a little wobble to it. Still the vibration persists. I used my old motor's balancer (identical but it had 320km on it, looked good, doesn't wobble)
I am also experiencing a high rev low rev nonsense from the motor. Some days it idles great some days it idles really high and I don't need to use the gas pedal at all, some days (sedom) it idles way too low. It makes my water temp climb of course. I noticed that when all of this happens, my water hose to the intake manifold is hard as a rock, completely under intense pressure.
I thought the thermostat was shot so I replaced it. Still it gets really hard. Is there soemthing wrong with my water pump? Could the killer vibration be coming from there? Maybe the impeller on the pump is screwing things up?
Help!!!
P.S. - The entire water syatem just got a rad flush with chemicals last week to make sure nothing was pluggin up stuff.
Help!!!
