My local mechanic is not sure about what is causing the vibration when my 2.2L engine is running. He is somewhat confident that the torque converter is worn and needs to be replaced. After the new part is delivered, I will bring the S10 to his shop.
This is a second diagnosis. The first time he checked, he found that the fan clutch was worn and needed replacing, which was done. That was a needed repair because before replacing the clutch, the fan could be wiggled with about 1/4" of forward/backward play.
Severity of vibration varies. At max, the rear view mirror in the cab gives blurred images. The driver side mirror, oddly enough, delivers unblurred images whether or not any vibration is occurring.
It vibrates the least amount in Park. Neutral is next. The most is when in Reverse or any of the forward gears, with the brake on.
Anther symptom I know about is a slow leak in transmission fluid. Now that I am aware, I check the fluid level frequently and top off as needed..
I can't tell for sure if there is any slippage in 4th gear, which the internet said was a possible symptom. Current guess = not slipping.
Another symptom from the internet is decreased gas mileage, but I haven't been checking mileage, so I don't know.
For the forum, I wonder what else might cause vibration - - Just in case vibration is still occurring with a new torque converter installed.
