eh..should i say anything?
i have a viair 450... in the mail being sent back on a warranty return. im getting a new one cause mine crapped out.
i have a few blowjax comp. Dc7000 and Dc5200, i like them over any other electric compressor (not includ. oasis) they are loud and have a bad rap of breaking, and i know a lot of people have had there problems, but i personally have never seen one fail or have any problems. only 2 downsides to them is they are louder then the viairs and pull more juice(but they pump way more air, i think the 450 is 1.74cfm @0psi, and the dc7 is 4cfm @0psi, and
[email protected])
you really need to asess your situation. is it your dailydriver? are you a mega switch hitter or just air up drive? do you have another vehicle to use?
if i didnt have these blowjax\aim\puma compressors(whatever you want to call them) then id probably be stuck on the side of the road b\c of my viair. I believe that i just happened to get "a bad seed" though. viair is very reliable if they are used according to manufactures specs, 100% duty, but do not push "a ton of air". id use the search button because it has been asked a million times. figure out what you want to do, but for a good starter, all around compressor, the 450 is a good choice.
