1 - 20 of 21 Posts
LQ4x4
Hello everyone! First off, let me just say I love this forum, tons of info, tons of great dimes. This build would’ve been nearly impossible without it. Buckle up, its gonna be a doozy. Im sorry for the poor quality cell pics, recently i bought a digital camera.
Ok, This is Veronica
She’s a ’89 2.8l/5 speed/4x4. My first vehicle, purchased April of 2008. I got her with a 2” body lift, 31’s, handmade square tube bumpers/spare tire carrier, a lot of stuff broken, dirty, missing, and ~215,xxx miles for $1400. Since then, minor mods here and there, quite a long list actually.
Engine: Not much, cause I knew I’d be swapping in a v8, I didn’t want to waste money on the 2.8l, student/young adult budget. NOT CHONICOLOGICAL .
-New 4.3 Hd 3-core radiator, hoses, t-stat, heater hoses
-New serpentine belt, idler pulley and tensioner assm., alternator
-TBI injector fix, Spectre aircleaner, fuel filter, fuel pump, distributer, cap, rotor, wires, plugs, msd ignition coil, ignition module.
Driveline: All stock, like a rock, except new front CV’s
Suspension/Steering: My first major upgrade on her
-2” Rough country lift kit (I didn’t have the cash or reasoning to go higher or SAS).
-PowerPerformance complete suspension and steering kit. Inner/Outer tie rods with their HD toe adjusters, upper/lower balljoints, pitman/idler arm
-3leaffab 3” lift shackles
-31x10.5r15 Bridgestone Dueler Revo 2’s (5x)
-brakes pads, shoes, rotors, drums, RF hub bearing assm.
Interior/Sound:
-Clarion VZ409, Clarion 4x6 fronts, 1600 watt Koiiler Amp, 2 12”Audiobahn Subs, Knukonceptz.com Power wire
-98+ column shift center console modified for 5 speed(every, and I mean every, piece is from a different blazer/pickup at the junkyard, haha)
-Black alligator pattern headliner (the lady at the fabric store thought it was giraffe, so when someone asks what it is, that’s what I say)
-Wink mirror/custom map light (one of the first things I did after purchase. It’s big and ugly, but hey, no blind spots)
-New window motors, fixed courtesy lights, other small stuff…
Exterior: Not my biggest concern, luckily the paint is decent, love the color blue I have, I think it’s a rare color, cause I’ve yet to see another, and believe me im always lookin. Rust is getting bad, I will address this later.
-15x8” black 8 spoke steels
-Custom Front bumper( big and ugly, was my senior project in High school, built it in a week, which was only 7 hours class time. Will be redone eventually.)
-4inch square fog lights
-Projector/halo ebay lights, led taillight bulbs, window screen mod
Well, that’s the jist. On to the swap
Since day one I knew the 2.8l needed to be replaced, but not because how it runs. All my high school friends are shocked/amazed/jealous about how long this blazer has lasted me. I had the oldest vehicle and its lasted me the longest. But the power, or lack thereof, has had me v8 hungry. So recently ive finally overcome budget issuses with a new great job. At first I was looking into vortec 350’s, but then I got bit by the LSX bug.
Swap:
-2003 LQ4 out of an Express van, 97k ,$1500. Running the truck intake. Aeromotive 340, new fuel lines/fittings/'94 fuel sender/'94 tank, corvette filter/regulator. Modified '99 f-body manifolds. Keeping A/C(in stock position). Miloden Oil Pan. Remote oil filter/cooler.
-2001 4L60E out of an Express van, Blown(failed Torrington bearing in low/reverse planetary assembly.) got for FREE!! From a buddy I worked with for showing him the inside of it. Took it to my school and rebuilt it. My instructor gave me a 4L80e low/reverse planetary assembly
(with 5 instead of 4 planetary gears) in exchange for my blown one, for instruction purposes. If im not mistaken, that essentially makes it a 4L65e… the fluid pump failed on the tranny dyno, so a got new one of those(don’t want to risk running a rebuilt one). will be runnin an aux Tranny cooler.
-236 shift on the fly transfer case
-custom driveshafts, motor mounts, tranny crossmember.
-8.5 disc brake axle swap
-98+ dual piston caliper/knuckle swap
-’93 astro hydroboost swap
-Current Performance wiring harness
-Order the rest of the new rough country lift lit that didn’t come with mine. The front diff drop especially, maybe the new control arms, or make my own.
Garage where the operation is taking place
Progress so far
Progress will be slow, because i travel for work, but dont fret, it will be done.
Thanks for viewing my thread. feedback is definitely encouraged
LQ4x4
Not a fan of the grille personally but you've got plenty of good parts to keep you busy for a while. Can't wait to see it all start coming together.
Yeah, that pic doesn't do it justice, its black window screen, layered twice and secured by self tapping screws through sheet metal plates. i like it, and its a great way to protect the condenser/radiator from rocks and bugs. same thing for the headlights, keeps people from flashing their highs at me, still provides great visibility. and if a cop says anything i can tear it out on the spot and not get a ticket, haha, a roll is like $5 at Home Depot. functional and adds a unique look. there's alot of parts i dont have pics of yet, ill post when i can. You and me both!
holy shit this is gonna be ill.
:evilg::chomp::bowtie:
LQ4x4
More pics
LQ4x4
Discussion Starter #8
IMO, front bumper looks way too big. To each their own though! Looking forward to progress
it's huge. haha, the bottom is perfectly level with the front crossmember. i will redo/build a new one. once i relocate the front diff, i can crank the t-bars up about an inch, which might make it look better.
LQ4x4
Discussion Starter #12
update:
OH NO!!
test fit #1 (no front diff installed)
2002 7.5 lsd, had trouble finding a 8.5, so this one will do until i blow it up, haha.
rear brakes
New vs. old
painted my intake in the wrinkle plus stuff, still needs a coat or two. the bracket and valley cover are just black
LQ4x4
Discussion Starter #13
Update:
rusty hole in my floor is fixed. welded and sealed.
installed RC differential drop kit, but the oil pan still hit, so i had to notch it. forgot to take pics. also added about 2" to the driver side of the g-force crossmember to clear front drive shaft and match the old crossmember. i also trimmed the p/s-alt bracket to clear the l99 wp im using.
Muffler and cats arrived
the waterpump and flaming river steering shaft kit should be here today. work is getting super busy, but im aiming for a june deadline. i just might finish this on the first page, haha.
LQ4x4
Discussion Starter #14 (Edited)
repost fail
LQ4x4
Discussion Starter #15
two updates in one day?!
Flaming River Steering Shaft kit
VVT camaro WP, bought from autopartstomorrow.com
it was delivered by ups ground, it came in a box that i would say was pretty snug, no padding, gashes in the cardboard from impacts, and the waterpump was facing down. And that box was put on top of a shorter box that was roughly the same width by depth. then both were place in a bigger box with brown paper around two adjacent sides and the top. the outside box had no clear "this side up" or arrows, and was "filled" from the wrong side.
I know its not very common to swap from a manual to electronic shift transfer case, but does anyone have some info that could help? i need to confirm exactly which transfer case i have. it was from a blazer, and has three buttons (2hi,4hi,4lo). i grabbed the switch and the lower harness from the same truck, didnt realize there was a computer module i should have grabbed too. and does the transfer case sense front wheel slip within itself, or does it use front wheel speed sensors?
LQ4x4
Discussion Starter #16
small part update today, big progress update sometime this weekend
Holley ls fuel rail kit 534-210.
not sure how well these will fit the truck intake, hopefully like glove.
and some more AN fittings. the twist tight fittings and gm efi adapter are for my fuel system, and then some -10 to -6 AN adapters for the oil pan outlet/inlet
Need LSx swap.....
if it was just 4hi/lo/2hi, then its a np233 tcase, not a 236. yes there is wiring and other electronics you will need (and encoder motor on the tcase itself and the TCCM which is located under the passenger side kick panel), but the vacuum system in place should be able to work with it id guess.
IMO, i would keep your manual shifting case. lots of potential problems with the electronic shift units...make sure your vacuum system is in good shape (lines/actuator/etc).
LQ4x4
Discussion Starter #19
youre right, its the np233. i forgot to mention im using the 233 instead of the 236, for ease of retrofit. because the 236 has the auto 4wd function, i believe it needs front wheel speed sensors and front abs input/data bus signals, blah blah blah. with the three mode np233, its just 2h,4h,4l. on saturday i went to the junk yard and got the module and the connectors for the whole system. i was trying to keep the harness intact, but that was proving to be a big pita, so im just going to make my own harness. i dont want to keep the manual shift because im using the floor shifter and console from the electro shift models. im not too worried about the electronic shift, cause im lucky enough to have a junkyard with plenty of s10s to pick off of.
LQ4x4
Discussion Starter #20
1 - 20 of 21 Posts
