41 - 60 of 93 Posts
· Founding member of DA
gotta love mass
it says up or down but only mentions lift kits
it even includes bigger tires
Chapter 90: Section 7P. Height of motor vehicles; alteration restricted
Section 7P. No person shall alter, modify or change the height of a motor vehicle with an original manufacturer’s gross vehicle weight rating of up to and including ten thousand pounds, by elevating or lowering the chassis or body by more than two inches above or below the original manufacturer’s specified height by use of so-called “shackle lift kits” for leaf springs or by use of lift kits for coil springs, tires, or any other means or device.
The registrar shall establish rules and regulations for such changes in the height of motor vehicles beyond said two inches. No motor vehicle that has been so altered, modified or changed beyond the provisions of this section or the rules and regulations established by the registrar shall be operated on any way.
· when in doubt lay it out
WOOO DOOGGGYY!!!
28-906. Mechanical raising and lowering devices
A person shall not raise or lower the height of a motor vehicle by mechanical means while the motor vehicle is moving on a highway at a speed in excess of fifteen miles per hour.
thats in arizona
· MonkeyNoma
i looked in the maryland laws and either i missed it or didnt understand just want to know i my truck will pass inspection with the 5/6 on it
I Looked thru the florida and i couldnt find out how low my truck is aloud to be?
And if any neon lights under truck is not aloud....like what colors arent aloud under it...
Sorry if i missed it but anyone see them and help me out please and thanks..
message me = )
Does anyone know the tinting laws for Michigan? I don't quite understand this..
"A rear window or side window to the rear of the driver composed of, covered by, or treated with a material that creates a total solar reflectance of 35% or more in the visible light range, including a silver or gold reflective film."
Does that mean 35% is the darkest you can go? I was always told you can go as dark as you please on the back windows. And I am curious about this as well..
"A special window treatment or application determined necessary by a physician or optometrist, for the protection of a person who is light sensitive or photosensitive, if the owner or operator of a motor vehicle has in possession a letter signed by a physician or optometrist, indicating that the special window treatment or application is a medical necessity. However, the special window treatment or application shall not interfere with or obstruct the driver's clear vision of the highway or an intersecting highway."
I have thought about doing this for some time, but I am wondering.. what is the darkest you can go with a "prescription"? Is it like a standard 20% or does it all depend on what your told?
· You can't say ****
For the Georgia guys who couldn't see it.
§ 40-8-6. Alteration of suspension system; operation of vehicle with broken springs
(a) It shall be unlawful to alter the suspension system of any private passenger motor vehicle which may be operated on any public street or highway more than two inches above or below the factory recommendation for any such vehicle.
(b) It shall be unlawful to operate any private passenger motor vehicle upon any highway, roadway, or street if the suspension system of such vehicle has been altered more than two inches above or below the factory recommendation for such vehicle.
(c) It shall be unlawful to operate any motor vehicle upon any highway, roadway, or street if the springs relative to the suspension system are broken.
(d) Any person violating this Code section shall be guilty of a misdemeanor.
Glad I don't live there anymore.
· Under Construction
**** the police! lol
· Always under construction
I'm pretty sure that "modifying stock frame", aka backhalfing your truck is illegal in CA, but I'm moving to AZ in a month and I know they don't care.
My question is what happens if I move back to Cali in a couple years?
If the truck has to be inspected to register in CA again, is it going to fail??
If anyone has ever gone thru this, tell me what happened and what I can do about it if they bitch. Haha
41 - 60 of 93 Posts
