I've been trying to track down the cause of my front axle not engaging and it appears that the vacuum switch on the transfer case is not working. I am new to S-10 4wd's and so I have a couple of questions before I start buying parts. First, does the switch just screw into the housing? Will anything drop out of it or cause problems if I R&R it? Next, what actuates the switch in the transfer case? Could a misadjustment or other internal transfer case malfunction cause the switch not to work? And finally, the indicator lights by the transfer stick don't accuratly reflect what the actual gear selection is. Could this be caused by the switch on the front axle being inoperative due to lack of movement of the engagement cable?
87 Durango 2.8 auto
Any input would be greatly appreciated.
87 Durango 2.8 auto
