1 - 20 of 21 Posts
Hi my name is Hayden i have a 1982 GMC S15 that iv'e put a 350 V8 with a NV3500 5 speed trans out of a 1995 S10 Pickup. I also transferred the Fluid clutch and Slave Cylinder from the 1995 to my 82 to go along with the Trans but after bolting everything up it's very stiff and the pedal can barely be pushed can anyone help me?
Thnaks
the new guy
make sure the rod is not at an angle. my son's 92 had trouble and I pushed it harder then normal and it turned out the rod was bent on the pedal to the master cylinder
Yeah thats what were thinking since we had to drill a hole in the firewall for the master cylinder it may be off a little.
the new guy
it did ours. it was really hard. it ended up bending the rod a bit so once we got stuff straight, we had to straighten the rod. once we got that straight, now the clutch is smooth as glass and (to me) very easy. but my son loves the truck and says its perfect and since we put the truck together for him, its good
Check to make sure the rod on the slave cylinder is on the clutch release arm. If not it will bottom out and not move..
Sent from my SM-G950U using Tapatalk
Yeah its up on there and i can feel the clutch engage and disengage but it's just very stiff.
Could be a pedal/rod position issue. Was it originally a stick or did you convert an automatic. If so, did you replace the whole pedal assembly with one from the same year S10. The 82's were mechanical clutch linkage and the hole for the rod might be farther down the pedal than later models with hydraulic clutches. That would make the leverage all wrong.
If you can find like an 85 or so pedal look to see if the hole's in the same or a different place. Or look at a 95 era pedal and see how far down that hole is. I'm thinking 1/4" closer to the pivot point could make all the difference in the effort required.
You may need to switch to an 1st gen S10 master since yours is 2nd gen. Although the difference is only 1/32" in bore diameter, which shouldn't make that much difference.
Discussion Starter #9
My truck was originally a 5 speed i took the whole clutch system out of a 95 S10 and put it in mine.
Then it is possible the hole is lower on the pedal because the original linkage was mechanical in 82 and may have required longer travel than the hydraulic. The farther it is down the pedal the harder it'll be to push, right? Does it start to engage at what feels like the correct spot? Or a little higher? Does the pedal go to the floor when fully disengaged?
Discussion Starter #11
We drilled a new hole and thought we lined it up but the clutch engages and disengages good but the pedal is super stiff.
Angle probably won't affect effort as much as you think. It's all in the pedal ratio.
Sounds like you might have drilled the hole in the wrong place for easy effort.
Discussion Starter #15
Do i need to re-drill my hole?
No idea. I don't know where you have it currently and don't know where it's supposed to go, but I do know that if you move it upward it will get easier because you'll have more leverage. It will lengthen the stroke, though.
Discussion Starter #17
What if i tilt my Reservoir up a little bit.
Tilting the reservoir won't change the leverage applied by the pedal.
Simple physics, the farther from the pivot point the farther it travels and the harder to depress.
Discussion Starter #20
It will make the pedal rod push straighter than what it is now.
1 - 20 of 21 Posts
