1 - 10 of 10 Posts
Good day to all...
We have recently released a complete cooling package for the V8 swapper.
http://www.s10forum.com/forum/f213/ding-ding-ding-ding-come-and-get-it-358519/
Although the pictures and description depict the LSx swap radiator, We have a configuration for the standard small block as well. Instead of a dual pass design, it will have the inlet to the radiator on the Drivers side more like a typical setup for the older style small blocks.
This is also $25 less than the Dual Pass design, so $450
Fans and shroud - $285
Condenser - $115
Total - $850 for all, and a limited time 10% discount for s10forum.com members brings the total to $765.00 for it all.
5% discount applies if you only want the radiator, or the radiator and fans without the condenser.
takes 2 balls in our game
Thats a great deal as long as it wont overheat in my books!!As everyone knows, the hardest part about the swap, is the cooling.In Florida with ac,anyway...:D
i like that setup u made up. i have a 95 gmc jimmy 4x4 with a 350. do u make 1 for that year. i also have a overheating problem 2. i`m trying 2 finish the truck before i leave 2 iraq again.
They are not really year specific other than I know for certain they fit well in the 94-up trucks. So your 95 is no problem.
I know the core supports in the older square body trucks are pretty much identical, but I haven't fit on to verify.
i see in the pic that the lower hose is on the same side as the upper hose. do u make it with the lower hose on the other side. thanks
No, only in the 2 styles, LSx (Both on Pass side), and Standard SBC (Inlet Dr side top, and Outlet Pa. Side Bottom).
also there is so many s10's out there that overheat!!This very well might be the solution...
1 - 10 of 10 Posts
