Unless you can figure out a way for your 91 S10 to generate class 2 serial data there's no way it'll work. Only analog gauge on a 2001 is oil pressure.
It is the design of the newer dash I was after and knew I'd have to build an instrument cluster from scratch. Just wondering if it will mount in the same as the older ones.
